- 8 Sep 2003
- Outside
So I’ve been going round the loop in terms of a new car and can’t really work out what I’m after so here’s the inevitable spec me... in case there’s an obvious gem I’ve overlooked. I’ve not really kept up with the market over past couple of years so probably quite out of touch.
Essentially I’m after a 7 seater in that it will usually carry 5 and need the extra flexibility. Budget is 30k, 35 at a push for the right car. Ideally I’d like an estate but the seating requirements blow that out so likely looking at MPV/SUV?
Driving wise, my mileage has bombed lately as work from home and when I don’t I use the train so generally speaking will be used weekly for quick runs round town and at the weekend for semi regular trips to Lake District (120 miles) so I’d assume about 6-8k a year (down from 25k or so). In practical terms I’d want to have a hefty boot and be able to chuck a load of bikes on a tow bar.
One of my biggest requirements is stability in terms of reliability and cost, ie. I need it not to break down and I need the running costs to stay stable (not necessarily low but not wanting it to be spikey).
Cars considered are fairly broad with different pricing.
Seat Alhambra
Ford S-Max
Skoda Kodiaq
Volvo XC90
BMW X5
Porsche Cayenne
The Seat and Ford depress me, practically great but feels like I’m giving up, the Kodiaq ticks a lot of boxes but feels like there’s better value to be found elsewhere, the XC90 is probably about 6-12 months out from being in budget in a nice spec, not driven one but love the look both internally and externally, X5 seems doable however it feels like it’s getting long in the tooth - I had an F10 7 years ago and it looks very similar and the extended warranty is pricey, the Cayenne scares me and I haven’t really given it serious consideration as with the Porsche badge as it makes me feel like the running costs will be a step above and the engine choice and spec at this budget probably won’t justify it.
I realise the sensible thing would probably be to spend half the budget on a Seat and Ford and the other half on something more fun but I don’t have the time to enjoy a second car to that extent. I may look to buy something as a second car for around 2-3k in the future however.
Help?
Edit: forgot to mention, open to purchasing and leasing, done both in the past depending on car.
Seat Alhambra
Ford S-Max
Skoda Kodiaq
Volvo XC90
BMW X5
Porsche Cayenne
Help?
