Spec me a fan controller
3 Aug 2004
Birmingham
Hey all,
Got a Gigabyte DS3 motherboard on the way tomorrow for my new intel rig. I think it only has 2 fan headers though onboard whereas my old DFI SLI-D had more.
So I thought I would invest in a fan controller. It will need to control 3 120mm case fans and a Zalman CNPS9500-LED. Preferably with an LCD screen included to display the current fan speeds and fully adjustable of course. Oh and it needs to look fairly at home sitting in my black Lian Li V2000.
So, any suggestions?
Thanks
Akasa AK-FC 03, does the job nicely for me..
Can control 4 fans, has fully programmable failsafes, many colours (facias AND lcd screen colour), lcd, and can monitor temps too.. all with an alarm incase things go wrong :)
Haven't got the temp monitoring bit working yet though, as i can find where on my motherbord to plug the cables in to... Any hints here? (sorry to 'steal' the thread.. the mobo is an asus P5N32-SLi SE Deluxe)
Are you talking about the temperature probes? If so you need to stick them in places like on the side of your CPU or somehwere in your case , maybe on your HDD using thermal tape
