Hi, I've got slight issue with cooling.
run PCS+ 390 in Nanoxia Deep Silence 4 and I noticed the side panel gets really hot while gaming as well as GPU temp rising to around 85+ degrees.
When I take off the side panel the max temps I see are around 75 which I'm ok with.
I run the stock Nanoxia fans - 1 in front, 1 at exhaust. they seem to be rated at 1300rpm, but I can only seem to run them at 1000rpm max.
I attach photo, the red rectangle area between GPU and PSU gets really hot. I need the fan airflow to reach further. I can barely feel anything 10cm away from the front fan.
so any advice on this? If no other option I'm looking for a 120mm replacement fan that could deliver better airflow.
thanks
thanks
