Spec me a fan!
15 Nov 2007
Hertfordshire
Need an exhaust fan for my case that hasn't got LEDs. Want the best airflow at the lowest noise possible (don't we all.)
Was going to go for the Noctua as it's the only one I've heard of, but the colour clashes terribly with my case...so does anyone have any good recommendations? Needs to run off a mobo header if possible. I know nothing about fans.
Yeah that Sharkoon is a beast; white blades would look great under my UV. Is the 2000 worth going for or does the 1000 provide enough air flow?
Yeah I know what you mean mate, it does to me too - they look like proper premium products. It's gonna proper clash with my black and blue innards though :(
I have 1000 on my Antec 300 and you can barely feel the air flow with you hand up to it (from inside the case), personally I think the 2000 would be better but there will be an increase in noise. So depends on what side of the trade off sea-saw you want to be on.
Could you not get some mat black car paint spray and give them a light dusting?
If you want lowest noise; the Xilence or Noctua.
Highest CFM, Sharkoon. Just got rid of my Sharkoon (phasing out all non Noctua fans :D). I could definitely hear the difference between the Sharkoon and the Noctuas.
setter - While you cannot tell us where you got them, are the new Sharkoon fans much more money than the standard, and how about noise compared to noctua ?
another sharkoon fan here...(excuse the pun)
got 4 of them in my p190 and they do the job very very well on a very low speed.
