you'll probably need to provide a bit more information
Do you plan to use it on camera? For portraits etc.? Or manually off camera? These kind of things decide what features you need.
Ok... budget range?
How about whether you want it to control other flash units?
Are you going to be shooting close-up portraits in small rooms or big functions?
If this is your first foray into flash photography I personally wouldn't splash out a few hundred quid on a flash. Go with a Yongnuo or a couple even, along with some wireless triggers. You can get a couple of flashes plus trigger and two receivers for around 100 - 150 quid, and if you decide to upgrade to the canon equivalent then you wont be too disappointed getting rid of a 30 - 50 flash. Just my thoughts though![]()
I got my new flash - 580 EX II delivered this week and so far of the few shots taken am very pleased. I have a wedding at the weekend so will be able to try it out in anger but at the moment I'm reading the manual to try and work out all the numerous functions.
Splash out for the 580 EX II - it's only money!
shall order it next pay-day \o/ - 2 weeks can always get more units to add too!
