Its looking like my fridge freezer is on its last legs, seems to be running more or less constantly and not super cold as you would expect if if it was just a failed stat, its barely cold enough
Its never been a good fridge, never seems to get cold enough, initially the compressor was swapped in warrenty because they couldn't find anything wrong to cause rubbish temps, didn't seem to make things much better and more or less just put up with it. I just get the impression that it is a very poorly designed fridge (and posisbly very similar issues to this one
) and now it seems more broken than it was by default.
So please, spec me a new fridge freezer, somewhere around 70/30 split. Existing one is 198L fridge (which is probably about right, but a little bigger would be advantagous) and 71L Freezer (which is too small), so probably looking around 240L/100L ?
Don't want to make the same mistake again, so want to try and avoid the more budget brands I guess, and definatly not a Fridgemaster again, You'd think with a name like that, they'd be erm... masters of making fridges, it seems not!
I'm guessing I should be looking at Bosch? Lievherr? What are brands like LG/Samsung/Kenwood/Hoover like?
