I had my house re-wired recently and I got the sparkies to put down some cat5e, he has fitted the network points in each of the rooms.
Most rooms have two network points, but I only have one near where the NTL broadband comes in. All of the cat5e cables (13 altogether) terminate in the
study. See pic below for setup. The ntl cable modem will need to stay in the front room as the optical cable isnt long enough.
I intend to get a wall mounted network cabinet + relevant components. I am considering power over ethernet enabled switches as I may in the future
consider putting in CCTV in the hallway etc.
I beleive the following is whats required.
24 port Patch panel (smallest I can get and allows extra cable to be fitted if needed in the future)
24 port switch (preferably power over ethernet)
punch down tool
cable tester?
RJ45 connectors
enough patch cables for switch
firewall - I will probably get this at a later date as its probably overkill for home use.
I already have a wireless router that I can use as an access point.
Another consideration is that as the network components will be left on all the time the more energy efficient they are the better.
Will I need two cable testers to test each cable?
Can anyone recommend what equipment they would use to do this?
Finally how easy is it, I have created a couple of network cables before surely theres not much difference when terminating the cables into the patch
panel and can anyone recommend a guide that might be useful.
Thanks,
punch down tool
cable tester?
RJ45 connectors
Thanks,
