please spec me a ddr5 system for as cheap as possible for AMD i will upgrade in the future, no gpu needed
Thanks - will this bottleneck a 4070 super if i get one in the futureCPU cooler is in the CPU box.
My basket at OcUK:
- 1 x AMD Ryzen 5 7600 Six Core 5.10GHz (Socket AM5) Processor - Retail (SKU: CP-3DW-AM) = £172.99
- 1 x Asus TUF Gaming A620M-PLUS WIFI (Socket AM5) DDR5 Micro ATX Motherboard (SKU: MOT-ASU-01397) = £133.99
- 1 x TeamGroup Vulcan EXPO 32GB (2X16GB) DDR5 PC5-48000C38 6000MHz Dual Channel Kit - Black (FLABD532G6000HC38ADC01) (SKU: MY-0B2-TG) = £99.95
- 1 x KIOXIA EXCERIA G2 1TB SSD NVME M.2 2280 Solid State Drive (SKU: STO-TSH-00981) = £58.99
- 1 x Phanteks XT Pro ATX Case Tempered Glass Window, Black (SKU: CAS-PHK-01442) = £50.99
- 1 x Phanteks AMP 650W 80 Plus Gold Modular Power Supply (SKU: CA-09Q-PT) = £89.99
Total: £606.90 (includes delivery: £0.00)
Not meaningfully, no, but as always: it depends on the game, settings and the resolution you're playing at.Thanks - will this bottleneck a 4070 super if i get one in the future
Thank you, i will order this on pay day =)Not meaningfully, no, but as always: it depends on the game, settings and the resolution you're playing at.
You're welcome, but please see my edit about the PSU ^^Thank you, i will order this on pay day =)
Will do ! yes and Seasonic are a good PSU companyYou're welcome, but please see my edit about the PSU ^^
I'd recommend waiting to see if someone else has a better spec idea too.
thanks yes the case is niceI would only change the motherboard to the asus-prime-b650-plus
Asus Prime B650-Plus (Socket AM5) DDR5 ATX Motherboard
Order Asus Prime B650-Plus (Socket AM5) DDR5 ATX Motherboard now online and benefit from fast delivery.www.overclockers.co.uk
Its the same cost but with the better b650 chipset and more m.2 support so you can just add a bigger m.2 drive at a later date for more storage. The Phanteks case will fit the MB no problem and look better than an M-atx IMHO. Although no wifi if thats an issue.
If you want better cooling on the case the XT pro has 3 more fans installed for another £16 which is a bargain as the tripple fan pack is £38
Phanteks XT Pro Ultra ATX Case Tempered Glass Window, Black
The Phanteks XT Series delivers outstanding support for a wide variety of hardware, such as the innovative hidden connector motherboards from MSI and ASUS.www.overclockers.co.uk
