Spec me a Gfx card
28 Nov 2005
Hi guys can any of you please spec me a gfx card with budget of £250 tops.
i play at 1680x1050 everything turned on full.
I was looking at the 260 or the 4850 ? or maybe the 4850x2 ?
Also is there much difference in the maxcore 260 and the core 216 ?
Any help appriciated thanks :)
Rest of sytem is:
e6600 @ 3.40
4 gig ocz ddr2
asus pb5
enermax 620
windows vista 64 bit
thats the rest of the spec.
Yeh i was looking at that card or the 4850 cant decide between the two :confused:
Also what is this 55nm ?
thnx
Rest of sytem is:
e6600 @ 3.40
4 gig ocz ddr2
asus pb5
enermax 620
thnx
psu should be fine :p
ehh i think a 1gig graphics card would be overkill for you monitor and 512 would be cutting so that card is right in the middle :D
and this 55nm is the new GPU arcitecture mate, which means it runs a good bit cooler :cool:
Well im hoping to upgrade the the hannsg 28" screen in a few weeks , so do you think the 260 would be the best option here?
and is it worth getting the maxcore or just the normal one and oc it ?
