Spec me a good sound system (Under £100)
29 Dec 2014
The "North"
Hi everyone, so the title is pretty self explanatory that I need a new sound setup for my PC. I play a lot of video games, occasionaly listen to music and watch movies/TV etc.
The current mark to beat is pretty easy as my current setup are some cheapo Logitech S(Insert Number here) 2.0 speakers that sound pretty awfull (As highlighted by a friend)
As always any help is greatly appreciated as sound/audio setups are definitely not my field of expertise :D
Edit: Logitech Z623 speakers
Won't get much better than these, truly outstanding set of speakers!
Thanks for the recommendation, would these be better than the Harmon Kardon Sounds sticks? :)
Didn't realize the HK Sound Sticks were under £100 now!
I am not too sure to be honest, you won't go wrong with either to be honest, I think it's worth going to a store and having a demo if you can
Guys, you are linking to a direct competitor, something that OcUK sells (speakers), which is against the forum rules, so if you wish to avoid a suspension I suggest you remove it pronto.
