- 7 Jul 2009
- Newcastle/Aberdeen
Well three or so years down the line after buying my original Xbox and the soldering on the headset decided to come apart, and the wires and too fidly for me to be bothered stripping them and fixing it (and i was looking for an excuse to buy a better one anyway) so i've decided to just replace it. Any suggestions? Cheap as possible really but i want something that will last, and having the ability to use it with a PC would be an advantage.
I've had my eye on this, looks comfortable enough (bearing in mind i sometimes wear glasses) but it was designed for the original Xbox so i think i would miss the talk on-off switch and the volume dial... is there anything similar with those for around the same price? I also found this but i have on idea how it compares and it still doesn't have those features.
Any suggestions? What do you all use? Thanks
