Spec me a headset
21 Jun 2004
Berkshire
I seem to get through so many headsets it's unreal, so this time round I want to make sure I get something which will last.
The main issue I have is long cables which become all wrapped around eachother after a while, the wire breaks inside and they stop working. Or the cable is fine and the connector breaks..
I have used:
- Logitech Cheap thing
- Sennheiser PC151
- Speedlink Medusa
- Creative Fata1ity
Had the creative 3 days and I've broken it (albeit my fault, tripped over the bloody wire as it was so long!!)
So I want some reccomendations on a Headset which will last. i.e. a thick cable which cant get tangled up. Budget of £100
Forget headsets, universally crap compared to proper headphones. Try out the goldrings from Ocuk and get a clip on mic.
Just search this section and a number of us have recommended them for a while, and those who have bought them are a lot happier after switching from steelsound, icemat, or other peripheral manufactuers crap attempt at a headset.
