Spec me a Heatsink, fans and fan controller
30 Nov 2012
I have just received a Bitfenix shinobi and so need a new load of fans 4 120 and 2 140. I don't particularly care about them being silent as I often have my xbox and head set on at the same time so noise is not an issue. I would also like them to be red as they would fit with my color scheme. I don't particularly want to spend more on fans than the case.
Now that I have a bigger case I also want a Heatsink (air) I have a budget of £30-£40. I was considering the evo 212 but some say the 612 is better or are there others.
A fan controller is more of an extra but I would prefer to be able to adjust my fans and my MB only has one 3 pin header and one 4 pin header so would make it tidier no splitters every where. I have a budget of around £30 for this as well
I feel that if i can get the cooling sorted then I can start upgrading the hardware. Sorry for the long post!!!
