Spec me a high speed internet connection
Man of Honour
17 Nov 2003
Southampton, UK
Right, I'm moving into a student house with 5 other people and I'm going to need a fast internet connection. I was looking at NTL 10Mb but they don't offer it at the new address, so I need alterantives.
Needs to be 8Mb minimum and preferably uncapped although I might consider a cap if its large enough.
So who do you suggest?
Burnsy
tolien said:
ADSL2+ has a "distance dependance" too though.
www.samknows.com is your friend (though postcode checkers aren't great), and you're going to need a BT phone line.
According to that site, NTL do service the address, but the postcode checker on the NTL site says otherwise, which is more liekly to be right?
Is ADSL 2+ referred to as ADSL max?
And i'm just over a mile away from the exchange.
Burnsy
Probably the NTL site - the best idea would be to phone them.
Nope. MaxDSL/IPStream Max is just a BT buzzword. It's using nothing but ordinary ADSL.
Mostly irrelevant, especially given that's (if it came from Samknows) based on a straight line distance.
