Spec me a HTPC cooler
19 Jul 2011
I have a Silverstone LC20 case with Asus P5B, Core2Duo 2.6Ghz, AMD 6450 passive gfx card.
I used an AC Freezer 7 Pro and that was fine until I upgraded the CPU (Core2Duo @ 2.4Ghz). The extra heat meant that the fanspeed ramped up often and it was noisy - in a HTPC that sucks.
I tried a Corsair A50 cooler I had sitting around, but thats too tall for the case and I can't put the lid on. (I did consider cutting a hole in the lid, but decided it would look horrible.)
So I'm looking for a cooler that will fit and is quieter and more effective than the AC Freezer 7 Pro (145mm) and not as tall as the A50 (160mm).
Looking for cheap, cool, fits in the case and fits S775.
Thanks.
OK, cheers guys. That's given me food for thought.
I think the H40 is out, as every fan outlet from the case is 80/92mm - there are no 120mm fan holes. I could cut some, but dont really want to.
