- 23 Mar 2010
hi,
basically i want a reasonable setup (not sure if this is called an HTPC) which allows me to do basically anything from listening to music, watching movies to streaming the internet (like YouTube)
after trying out XBMC on my PC, i was stunned by how it looks. and its a must have!
ive did some research and many people said getting the Acer Revo with XBMC on windows 7 is the best choice...and will play 1080p.
well..i def want this setup to be future proof. but not sure how much it would cost overall. maybe a decently cheap setup could do?
so, the TV. i want a decent TV obviously, but there are so many makes and i dont know where to start =/
the media player, or nettop (i think) ...which is the Acer Revo. but not exactly sure on which model is the best choice. or is there better?
il be playing files like .MKV .RMVB .AVI etc. (mostly asian movies xD)
so the budget:
TV - depends really on size.
MEdia/Nettop - max around £200
just to let you know. this is the first time im ever doing this so im a bit of a noobie. not exactly sure on the prices of these products. but correctly me if i get things wrong xD.
the reason i want this is because it may be worth the point. instead of spending a small amount on a WDTV for films. whereas if i could get this, i feel its more beneficial in life and il use it more.
anyways please help out xD
feel free to mention any other hardware, as it may help =)
Thanks
so the budget:
Thanks
