spec me a htpc
17 Aug 2005
Gloucester, UK
looking for a nice system to go in the living room, to play 720p / 1080p movies / clips and do some web browse / bit of gaming. just wanna see what u can come up with, need the case and all insides, plus a wireless keyb / mouse. limit is about £1000
Not bad spec but don't need 2GB of RAM, and videocard is a bit too posh. Could use onboard, if it has it. Could get NSK2400 instead. Also need IR remote/receiver kit. Standard RAM will do also.
Easily. You only need AMD X2 3800 for 1080P playback H264. The graphics car really doesn't do anything, you could get away with a much lesser card (7300GS) The 7300GS has 3 missing features, but that's only if you use purevideo. FFDSHOW uses CPU power, so doesn't matter your videocard doesn't have it. I'm using 3700+, stock, 6150/ATI X300 and 1080P H264 is just topping 85-100%, but smooth playback.
