spec me a i7 setup for £1500 ?
18 Apr 2009
hi looking for a new setup i currently have a c2d e6300 overlcocked with 4gb ram i am looking to have a new setup i have a monitor case and keyboard so just need the base unit really im favouring a fairly denent looking and case with watercooling in the future so knock ur selves out any help will be appreciated
Under budget, but gives you some idea of what you can have.
my two pennies, the PSU is overkill but would allow you room to maybe add a 2nd 285 in SLI later if needed
Edit: didnt include OS so add another £90 for that
With a budget of £1500 I'd definitely look at getting an SSD. As in my spec, all the essentials are adequately covered and you still have cash to burn.
I have a Samsung 64GB SSD that I run Vista and my apps from, it's fast and totally silent.
lol i spent that time speccing the pc and then realised you wanted a case too. my bad :p
If you got a corsair PSU instead and removed 1 noctua fan and 1 hdd you could stick a nice case in their stead.
With that budget you can get this, main difference from my original spec being A) the gfx card, a 260, which should still be fine for most games on max settings still, and you can always add another later to go SLI B) the PSU is nonmodular, meaning any leads you dont use you have to tuck away, which should be quite easy with this case
If you wanted to shave a bit more money Id look at the case personally, thats a nice case but you can have one cheaper
Enjoy
