Spec me a Japan!
4 Mar 2006
Wales
Ok, that title doesn't actually make much sense.
Basically, I'm looking for traditional Japanese male clothing. Similar to what they may have worn in the feudel time, I believe they were some sort of robes possibly, not entirely sure.
Basically, I'm not completely aware of what they would have worn, and need to acquire a high quality costume.
what was that word..... weeaboo or somthing?
Get a Kimono and some wooden sandals. Long hair of dark coloue.
Admittidly I had read your post and thought you were being a sarcastic little so and so, but fair enough if you were being genuine about it..
As an unashamed Japanophile I thought I may be able to give better advice if I knew specifically what it was for. Although I'm happy to admit period outfits aren't really my area, so doubt I could help much either way. ;)
Oh, and for assuming I was being sarcastic; You all fail. :p
as per above. more info please?
you could just google for kiminos.
or would a normal keikogi and hakama suffice?
depends on what u wearing it for
Basically I need noble, courtly attire from the time. Preferably in a blue/white colourscheme, but not necessary.
Failing that (possible expenditure), I would be looking at some comfortable garb that could be worn by samurai/shoguns while they're not in their armour.
It's for a perfectly nerdy reason of live roleplay. so needs to be as genuine as possible. :)
Thanks for the current info, should give me enough to go off. If anyone can give me better with this info, feel free to comment :)
Maybe something like a keikogi?
or
http://img219.imageshack.us/img219/4348/keikogipt5.jpg/img]
or
[img]http://img219.imageshack.us/img219/8459/keikogi2iz4.jpg/img][/QUOTE]
Hmmm, as I say, I'd rather find some form of courtly attire. I'm aware I may have to fall back on Haori/Hakama etc though if I can't find anything particularly suitable :(
I think this is what you're looking for, dont know where you'll get one though
it seems like its about 10 or so different pieces to make the outfit
http://en.wikipedia.org/wiki/Sokutai
bored looking around found this might be useful if you want to try and find the pieces seperate and put one together, its the second one.
http://www.sengokudaimyo.com/garb/garb.ch02.html
or you could just go as
monkey, instant win ;)
