Spec me a Kraken X62 Replacement
1 Nov 2011
Portsmouth
As title really - Cam software is appalling, so I can't control the pump/fan speed or RGB. It's 3 years old, so I'll be putting it on eBay for someone else to "experience".
I'd like another 280mm AIO, as it fits well in the front of my Jonsbo W2.
Seen a few styles that allow further additions of GPU/rads, so happy to consider one, but budget limited to £150.
I have a 3700X on the Gigabyte X470 Aorus Ultra Gaming, and an EVGA 2080Ti XC Ultra Gaming.
https://www.overclockers.co.uk/giga...ocket-am4-ddr4-atx-motherboard-mb-56z-gi.html
Cheers all.
I have a Kraken x52 and can control rgb and pump/fan speed using Cam software!
Many only niggle is it takes a few seconds for cam to kick in upon win loading to silence the fans/pump.
Cheers all.
Hade no problems with that software thought it was pretty good
As to a 280 i use a frostflow 280 by id cooling found it to be one of the best aio's out there its cheap £50 or less. Fans arnt arnt the best though got noisey after a years use i replaced mine fans and pump controlled via asus fan software
Managed to grab a 280mm Alphacool Eisbaer Black for £68 delivered - X62 appears to go for 70-90 quid second hand, so hopefully I'll break even.
I'll keep an eye out for a compatible 2080Ti block to add to it in the new year - although I'm not sure if that'll require another 240mm rad...
