- 22 Aug 2005
- Clydebank
Wondering if anybody knows a language that I can look into the essentially does the following?
Allows to write an application (not a web app, but a 'real' app) but has a coding style similar to PHP...
I find my self requiring to do little 'converter' utils, and scriptable situations quite often, and I usually use Batch, or create a cumbersome web app to do the same. I'm talking things like renaming a bunch of files, processing some images, moving files based on db lookups, generating textual logs, csv/xml etc
But batch is quite convoluted and slow. Getting it do what seems like simple things can be a nightmare sometimes (I've programmed massive multifile scripts in batch before as well as small one offs)
Using a PHP script works fine, but not for any serious processing as it all runs on a web server and i want more power, I sometimes need things like combo boxes, or a folder selector box, or perhaps ability for someone to draw a 'zone' on an image etc etc this does't happen through a web browser.
Also needs to be portable so a compiled executable/set of install files is required.
Sooooo what should I be looking at? Windows / Linux doesn't matter. I saw ages ago some video demos of NEXT with GUI OO literally drag and drop style programming that looked good, but probably not useful these days
Any suggestions..?
Any suggestions..?
