Spec me a Laptop with NVIDIA Graphics & Expandable Storage
22 Dec 2009
Upper Skurt
Hi,
I am looking to replace my desktop with a laptop that has NVIDIA graphics and expandable storage.
At the very least I need to be able to fit a 4tb nvme, preferably larger so I assume I need total storage capacity to be around 6tb or 8tb? Larger is better.
It will not be used for games, it is the NVIDIA cuda cores I need, even if they are a low number. Latest display tech is not mandatory as the laptop will mainly be docked and a 30" monitor used.
Older models that fit my requirements preferred but later generation tech is also acceptable. I can stretch to £1500 excluding the cost of expandable storage but if there is something around the £1000 mark that is OK. Second hand in good condition also OK
Any advice most appreciated.
Thx
Bintos
I can put my three-year-old Legion 5 in the MM for you. It has an RTX 3060 and two M.2 2280 slots, currently with 1TB and 2TB drives but this can be changed.
