spec me a largish mp3 player.
4 Oct 2003
i currently have a phillips 20gig mp3 player, however its a ex demo from work, was damn cheap but it has no battery life to speak of and the sofeware is shocking imho.
So what i am after is something with more than 5gig (i dont use all the 20 so not too worried) that has a nice way of moving the mp3 over (drag and drop into folders would be amazing!).
Cheers!!
iriver h340. Drag and drop (Windows Explorer) Rockbox so loads of codec support, customization and open source firmware.
For drag and drop then id recommend Iriver or COWON, the older Iriver H340 is hard to come by as a new unit, so for that your looking second hand, or the new Iriver H10 range, which is a nice player, i have one myself and would recommend one. Also check out the COWON iAudio range although they may be a bit expenive.
