Spec me a left handed joystick
8 Oct 2011
Surrey
Can anyone recommend me a good left handed joystick for use in Flight Sims - mostly for FSX ATM? Preferably with throttle controls on the right so I don't have to perform contortions :(
I had a Saitek Cyborg Evo which could be tweaked for right handed or left handed use, it had a throttle in the middle at the back.
Don't think its made anymore so you will have to find one thats second hand.
cannot recommend you one, although google "LEFT HANDED JOYSTICK" I got this one http://forums.vatsim.net/viewtopic.php?f=8&t=64473 also lots off other discussions etc.
Kenneth.
PS it also mentions the throttle which can be swapped to the right or left, also if you have a throttle already then ignore the one on the joystick using the independent one instead.
