Spec me a linux box.
29 Jul 2011
Near Northants / MK
I've got a case that can take a M-ITX Mobo. So my main plan is to build a rig to run something like Ubuntu or Mint on.
I want to remain budget I will probably get RAM from the MM etc. But still put it in the spec. Main uses will be messing about and collecting dust. :DDD
Spec away
Onboard graphics are needed.
http://www.overclockers.co.uk/showproduct.php?prodid=MB-330-GI&groupid=701&catid=1903&subcat=1949
Unless you want something passive then this one
http://www.overclockers.co.uk/showproduct.php?prodid=MB-500-AS&groupid=701&catid=1903&subcat=1949
Throw in 4gb of cheap DDR3 and a harddrive and jobs a good un, got a 160gb western digital sat here collecting dust and your local ;)
Would something like this suffice:
http://www.overclockers.co.uk/showproduct.php?prodid=MB-365-GI
Also is the HDD 2.5" - Thats all I can use.
To the mods: I am not discussing a sale I am just generally asking
I'd go with an intel build.
Even though the M1s are great boards and the APUs pretty decent, the drivers aren't great under linux. Main issue I found with them is the network adapter suddenley disappears. Not useful in a server :(
Good point. totally forgot about the lack of support for amd/ati on linux.
so its either an atom board or something like a second hand i3 530 and h55/p55 mitx board.
