Spec me a load tester and volt meter
20 Sep 2006
Hampshire
I've been meaning to get these for a while as I can use them many times over and get a fair amount of use from them.
Problem is, I don't really know anything about them. Can you guys recommend one to me? Doesn't need to be fancy, just be able to load test car batteries and a simple volt meter to measure... well, volts :p
Cheers!
Get a digital automotive multimeter - not only will it do battery load/cranking/charging etc plus all of the simple stuff like continuity testing/checking fuses/relays etc but it will also do ignition timing and the like and a bunch of other useful stuff.
Mine was about 40 quid iirc. Worth the money.
I got mine from halfrauds ages ago, but any decent motor factors should have them. Could try machine mart also.
For a cheap & cheerful voltmeter I'd recommend this, as it has a hold function & AC volts. You'll need to be able to measure AC voltages to do a ripple test on the charging system:
http://www.maplin.co.uk/ut-30b-digital-compact-multimeter-46498
For a slightly better one, the Gunson G4187 is pretty good & can be had for about £50
For a load tester, just pull out the fuel pump fuse so the car can't start and hook up your voltmeter.
9.5V and above for a ten second crank is a winner!:D
