Hello,
I currently have two HP Microservers with AMD Turion(tm) II Neo N40L Dual-Core Processor running at 1.5Ghz.
One of the servers is fully used as a UnRaid NAS.
The other only has the one disk in it and I use it to run SAB, CP, SB & Headphones plus any other general linux things I want to do.
I'm beginning to think that the box is not really correct for what I want to do. I want more CPU power (or Cores) but not all the available drive space.
If I was to build from scratch what CPU would you recommend to give me a power boost. Not fussed about size or heat too much as it sits in the rack hidden away.
Thanks in advance
Simpic
Thanks in advance
Simpic
