Spec me a low powered machine
That really depends on a multiple of things:
What your budget is
If its a branded PSU(and other details about the psu)
In honesty though, i doubt 200w will be enougth and its time to be upgrading to a newer one.
With a 200W PSU you have to remember that you will not get the full 200W thats specced. It will probably borderline 160 - 170W.
You using a power brick off an itx pc or something? You can get away with a lot on just 150w, but if you push everything it'll defo crash on you. Could look at a undervolted/clocked be-2300 and an matx board
Nah its a PSU ripped out of a shuttle and forced/jammed into a rackmount server. Its currently powering 2x IDEs, mobo plus 2x pentium IIIs...
I'm surprised that its stable and going strong... so that got me thinking, whilst I wait the arrival of 'proper' replacement parts why not upgrade the motherboard and cpu to c2d
Maybe if it was a Shuttle? Mine is 300w i think but i have quite a power hungry fx card
Ooo its from a shuttle, missed that one .... build a shuttle then :)
Just thinking, we recently had some problems with a pc, 2 hdd's (not sata) an old Durion 1ghz running on 200W. It was very unstable and hard drives kept timing out, till about 2 weeks later when the psu blew up! Stuck a 300W psu in and its been fine ever since. After that, i can't imagine a dual core cpu working on 200w
Yea it can be done...
Are you going Core Duo Core Duo , i.e. mobile cpu T2xxx, T5xxx or T7xxx???
I run a T2500 in my main rig, run quite nicely 2 x 2.0GHz & 2MB cache
