- 30 Sep 2006
- Midlands, UK
Needs to be a max of 58mm deep.
Please and thank you
Some good info and some not. While de-lidding usually lowers temps some, it's not always needed. How much it helps varies with each unit as well as between different models. Two identical CPUs will not cool the same because their TIM seats are not always the same. Add overclocking voltages and the silicone lottery and individual temps vary dramatically. I would figure out what cooler to use and get case airflow optimized before if de-lidding is needed.Needs to be a max of 58mm deep.
Please and thank you![]()
You have Shadow Rock LP in ML08? How can that be? ML08 specs say 58mm CPU clearance and Shadow Rock LP is 75.4mm tall. Did you not use a fan on it?https://www.overclockers.co.uk/b-gr...p-low-profile-cpu-cooler-120mm-bg-10m-bq.html
job done
i had the same case, this is a good as you get without cutting it to use an AIO, but then you lose GPU space and need to go for an ITX gpu
As I said above I don't see how Shadow Rock LP at 75.4mm with fan will fit in a case with 58mm CPU clearance.Thanks fellas,
right, i'm using a stock cooler as it was all the shop had to get me up and running as i forgot to order an AFM cooler with the cpu.
The case imho doesn't really cater for extra fans, however because of its design most of the cabling can be bundled up low and behind the psu and doesn't impede airflow around the inside of the case.
I'm using a GTX1070 Ti mini, its got 2 fans and is around 170mm long i think.
I'd be interested to know how P4Clock managed with a Shadow Rock as well. If its possible i might try it as well.
Ah, now it all makes sense.My mistake it was scythe big shuriken 2, its about £30 and a very good cooler, will massively outperforme stock and will even get you an OC if you set up case fans right
the cooler is 58mm tall, i will send you a link(not a shop link) via trust
well that's just confusing for the sake of it. Why noteither list of sockets, or just say "the whole frikkin lot"?All LGA11xx have same 75mm hole spacing.![]()
