- 16 Nov 2010
- Swimming in a lake
Ok, I'm looking for something a bit different here...
As we can see I already have a lovely K62
However, I feel like doing a mini-case mod kind of thing.
Not wanting to ruin the K62, I thought I might try a little project just modding a case, and maybe going from there...
This does however mean I'm looking for a case to try this out on!
I'm looking for something fairly small, but not too small, I looked into the idea of SFF, but am not so sure! Really I want something with the measurements below or smaller
400mm D
400mm H
200mm W
With a few simple features:
Preferably ATX supported motherboards
Reasonable use of size so you could fit a basic rig in to it (maybe even xfire low end ATI GPU's)
A space behind the motherboard tray so I can at least try cable management!
Reasonable quality
I'm looking for a fairly basic project, with next to no actual drill/dremel use, but maybe a simple paint and fan modifications!
Budget is a Maximum of £40, but am more than happy to pick up something second hand so off the MM/Bay. In fact to be honest, I'm expecting to have to go second hand to get a reasonable quality with these features included...
I was looking at the possibility of a SG03 but these (with delivery are more around £60) and also don't think they quite meet all the requirements above!
Get your thinking caps on people!
kd
400mm D
400mm H
200mm W
Reasonable quality
kd
