Spec me a MCE PC
18 Jun 2003
Southampton UK
What I want is everything apart from a case and the harddrives. I want it to be powerful enough to play a blu-ray disk at 1080p and it also needs to put out at this resolution. No budget but try and keep it as low as possible without using budget hardware (I dont have anything against certain budget hardware but the guy i'm building it for does!!)
If you hadn't guesed it needs to include a blu-ray player and a Vista license. As long as the M/B can output digital theres no need for a soundcard.
Thanks in advance for the help.
