Spec me a HTPC build please...
Currently using a Acer Revo r3700 for Kodi (Openelec) but would like something with a bit more power so I can run any skin, load the artwork instantly etc etc
Would like to build it in a av receiver sized case with possibly a display on the front. No budget at the mo but it only will be used for watching movies etc so no gaming what so ever.
Would like it to be able to do 4k and 3d if I wish. Would also like a bluray drive so I can get rid of the PS4.
I've got a Corsair H55 CPU cooler spare and some fans but that's about it.
Can you fit a gtx970 is these cases or is that overkill? When I upgrade my gaming pc that will be spare.
Any advise would be great, thanks.
Tobias.
Tobias.
