Spec me a mega fan!
20 May 2009
I need a fan for a project of mine, possibly 3 in fact!
They'll be mounted to an oil cooler on a bike so noise really isn't an issue, need to be 92mm and push/pull as much air as possible through an oil cooler which has a fin density about the same as a thermochill rad.
Dust, moisture and heat proof would be a bonus and the higher rpm the better.
Spec away!
Cheers
:D
Was looking at delta's, not with those sort of specs though, some of those really shift some air!
4800rpm, 102cfm and 53dB from a 92mm fan!
I'll look a little more when I'm home on the pc.
Cheers!
They do automotive fans as well, if that's what your project is, unless your project is using an oil cooler for a pc build??
Yea I seen the automotive ones, they're for a turbo charged gsxr but space is extremely tight and pc sized fans are about all I can fit in.
Haha that is awesome! I suppose fans don't matter on that engine, as noisy as you like. :) My bandit feels nice and hot can't imagine how hot it would get if it was turbo charged. I think heatproof/weatherproof would be a good idea I can't imagine my case fans surviving long on a motorbike.
There's a build log in the Bikers Cafe, just updated it so take a look through when you have some spare time.
Just bought 3 of the most powerful ones I could find! Couldn't find any of the 4800rpm ones in the UK so went for some 4100rpm ones, 90.05cfm and 50.0dB!
Should work...
:p
