Spec me a mid-range monitor
Permabanned
10 Apr 2004
Darlington, County Durham
Right, looking to replace the CRT on my other machine. Mainly to save electricity costs, because it doesn't turn off when the graphic card sends out the "turn off" signal.
Currently a 17" Hansol 710D is being used. It is used mostly for internet use, and a decent amount of Photoshop work - but not serious PS work, more playing with graphics and art.
I don't think a 22" is reasonable, and would ideally like to spend as little as I can get away with. I was thinking of a 19" monitor, which you can get for around £130.
Anyway, I think I'll set my budget as £150 - a VERY maximum of £175, if the monitor is worth forking out the extra for.
