It's been nearly 7 years since I built a PC, that is to say I have literally no knowledge about current ATX sized components, let alone the mini ones. I did consider reading up on all the available stuff but when I started, quite frankly, I was overwhelmed by choice and I know there are plenty of well informed people here that already know everything I want to know. I'm hoping from this thread I will be able to get a better understanding of what's on the market, for me!
How do I use my PC?
What do I physically need from the PC?
What do I already have? (I'm coming from a laptop)
Ideally I'd like to budget about £300 however I'd like my needs catered for before my budget, if what I want is more then I'll just save my money and wait for the next payday so I can afford it.
So really, just point me in the right direction with the type of components that will suit my needs. Feel free to create example set ups.
Thank you to anyone that helps me out
How do I use my PC?
- XBMC - 1080p video playback is a must
- MS Office
- Web 2.0 stuff (i.e. needs to handle flash/html5/java apps)
- Un-RARing stuff
- I'd like to add source games to my list but in all honesty I haven't had steam installed for over half a year now so it's not really a priority and I could live without that functionality
- 2 2.5" hard drive slots with at least 1 being sata 6gb/s(1SSD and 1HDD I already own). Possible a 3.5" HDD slot (but not if this impacts on the size of case)
- I'd like quite a small case (Silverstone Sugo SG05 for example)
- I'd like it to be as quite as possible
- Needs to be able to power dual 1080p screens
- At least 4 USB 3.0 slots
- 2 2.5" hard drives and a 3.5"HDD in ext-caddy
- Screens
- Keyboard+mouse
I did decide to actually do a slight downgrade on the ram, one 1333 cas 9 stick, I have no idea what sort of heat this thing is going to generate and for £20 I can easily buy another stick, as I barely game anyway I think it'll be perfect for now (plus the mobo says 1.5V for the ram, the previous set was 1.65V). £300 including p+p which is bang on my budget, I'm going to be driving home fast from work on Wednesday that's for sure
