Spec me a monitor MAX £150
29 Jul 2004
Glasgow/The Netherlands
So my monitor gave up on me last night (17" sony) and im looking for a new monitor, max i have to spend is £150 (would be more but we have a baby on the way).
So OCUK spec me a monitor!
TIA
True
Need some more information to select a suitable screen.
Resolution: 1680x1050 or 1920x1080?
Panel type: TN (for fast response times) or PVA IPS for better viewing angle colours (probably out of budget unless you buy second hand
Inputs?
You see where I'm going :)
It's a shame your budget can't stretch to £200 otherwise I'd pimp the Dell 2209WA without hesitation.
Well there has been a recent thread here for a 24" benq monitor being sold at ocuk for £155 (and you'll get free delivery as a forum member) so that's in budget when you consider other resellers charge for delivery. Sounds like a good monitor for the money and benq are a good manufacturer, I used to have their 241FPW and loved it. Might be worth getting involved in that thread and asking questions.
ok thanks, will take a look.
As I am a forum member, i get free delivery, but I live in Holland do they still do free delivery?
Er I'm not sure, if you put the item in your basket and go to the last page it should tell you I think. No idea if it's just for UK delivery sorry.
TIA
True
I ordered the BenQ HD2410HD for around £150 delivered. Was also considering the Dell S2209W which was on sale for £135, but decided to go for the bigger screen.
Though today the Dell S2309W can be had for £140, so I would have probably gone for that.
