Hi!
K, so I need a new monitor...
I have NEVER bought a monitor before, so I have no idea. At the moment, I use two CRTs, both the same size. If I measure diagonally across the glass (is that how you do it?), they are 16 inches across.
I want a flatish one to take to uni, and am happy to buy just one, as I can always use one of these old CRTs as my second screen.
I will use it for (in approx. order of usage); Browsing/MSN etc, apps such as photoshop and dreamweaver, gaming (BF2 and LFS mostly), and watching DVDs.
Do I want a widescreen? The OcUK Value Hanns-G HW191D 19" Widescreen looks good, but if it's 19" diagonal, does that mean it wont be very tall compared to a regular 19"? And is widescreen worth having, anyway?
I have £150 to spend.
FINALLY, to me I reckon bigger will just be better, I've never looked at a monitor and thought anything of it other that "ooooooh big", all this contrast ratio and response time stuff just confuses me. I do like a stupid resolution though.
Any advice appreciated, sorry for the long post
Thank you!!!
 Thank you!!!
