 - 22 May 2011
 - Manchester
Looking for a DisplayPort capable monitor, 24 inches, ideally with other inputs such as HDMI, with a fast response time as I will be using it for gaming amongst other things.
If I could get 120Hz or IPS that would be great but I also want it to be reasonably cheap, £150-£200 kind of range. Any ideas? Just names would be great doesn't have to be one that Overclockers sells...
 are you sure that adaptor would work well? Thanks for your help anyway
 i'm not specifically looking for non IPS, just one that is good for gaming and is not too expensive. I will be looking to buy June time so i'll look around for which monitors to get closer to then.
