Spec me a monitor
24 May 2011
West Sussex
Hi all,
A friend of mine has recently got a ATI/AMD v5700 gpu for doing some basic solidworks on his home pc. He currently has 2 old VGA only monitors. Thu graphics card has 1 dvi and 2 DP but with 1 dvi-vga and one DP-vga, only one monitor will function.
He is looking to get a new monitor to replace one of his current monitors and also in the hope that it will work well with what he currently has. low cost is preferable. 23-24" preferable. 1080p. budget around £100 or less please.
I think having a DP input would be useful but if you know more about the v5700 and what video out configuration it can do the please spec otherwise. Thanks.
