Spec Me a Mono(B&W) Printer
28 Apr 2011
Barnet, London
I hardly ever need to print things, just the occasional postage label. I currently have a scanner/printer that takes colour cartridges and it's not all that reliable when I need to print something after 8 to 10 months of it doing nothing.
Is there a reasonably priced, black and white printer, maybe a laser printer that doesn't need ink that I should replace it with?
Thanks.
I have a Brother mono laser printer, bought it about 4 years ago and it has been brilliant and cheap to run. Like you I only do occasional printing, before that I had an Epson inkjet printer and it only lasted 18 months before the lack of use killed it.
They start at about £100 without scanner, mine has scanner and cost me about £120.
Check local classifieds, laser printer resale value is pretty low and you could pick up an absolute gem for 20-40 quid.
The reason for that is that maintenance can be pricy. As you can get new one with toner for 80 quid, I dont think its worth the hassle.
I used to have a inkjet printer, I didn't use it often and when I did, ended up using most of the ink up trying to get it to work. So I bought a Samsung Xpress M2026 laser, when I bought it, it cost approx £35.00 I've replaced the toner once at a ccost of £!2.00 it's a good lille printer you can leave it for months and when you need it switch on and it works stright away.
Did the same, but got a Ricoh sp213w printer for around £40.
Had it a few years now and still on the original toner. Hardly use it now but when i do, it just works.
Go with reasonably priced laser, check oem consumables cost and win 10 compatibility. Most choices will do what you need ok
