Please spec me a motherboard and cpu I would like to be able to overclock @4gz plus as cheap as possible. Been looking at 1155 /1156 motherboards.
Right don’t slam me chaps, now I used to be into the overclocking lark many many year ago but haven't bothered in many years, so now I want to update my pc for something I can overclock more. Now I know that 1155 is the norm now but I’m looking at 1156 and 1155 from what I can remember the 1156 and 1155 chips I have seen from £50-£70 used mainly
Intel Core i3-550 Core CPU Processor 3.20GHz/4MB Cache/09A L0148158 SLBUD £62.46 1156
Intel Core i3 540 Processor (4M Cache, 3.06 GHz) 1156 £57.03
Intel Core i3-540- 3.06GHz Dual-Core (SLBMQ) LGA1156 £54.99
Intel Core i5-650 3.20GHz/4M/1250MHz SLBLK CPU £59.31
Now my goal is 4gz plus so what can you guys recommend I’m also after a motherboard to go with it as well. From what I gather my best bet motherboard wise From searching I found this P67, Z68, Z77, Z75 or X79 I’m not sure if many of those top boards are in my price range unless they are at a good used price.
I would prefer a pro 1155 or 1156 motherboard as I gather they have the most oc features for cpu
Looked at this board but not sure if it has enough for oc 4gz plus ASUS P8H61-M PRO the only reason I picked it was because from what I have read the pro boards have the full oc bits
Yes I want to do this cheaply so what can you guys suggest.
I used to use computer fairs a lot so I can locate most bits cheaply, thank you in advance for any help given.
