Spec me a motherboard and DDR4 to go with a 4090, and a 12400 please:)
18 Oct 2002
Altrincham
Hi folks.
Luckily managed to get a 4090 this week (whoop.)
Can someone spec me a motherboard and DDR4 memory to go with a 12400? I think whatever is the best value I can get at the moment, having spent a fair chunk on a graphics card already!
Just going to ask why your pairing a 4090 with a 12400, think you should return the 4090 and get something cheaper if budget is a concern.
Because there is no rule that says you have to have a top end CPU to go with that card. Have you seen any of the benchmarks?
Seen a few reviews and seen the 4090 can cause cpu bottlenecking of a 7950X at 1440p,, and think on some games a 4k (need to go back and check) so a 12400 would hamper a 4090 even further. There are no reviews of a 4090 with a 12400 yet, as you wont be testing the gpu, but rather the cpu, so a bit early for that.
Point is, if you're spending £2k on a gpu then slotting it in an existing build, that's one thing, but if you bought a £2k gpu and then are putting it in a new build based on a 12400, you'll be holding back your gpu...in which case you'll be leaving performance on the table, and should have just bought a cheaper card. If a new build of 4090 I'd be looking at a 7600X, more 7700X and/or 12700k
If you want to compare, there's plenty of yt showing a 12400 v 12700k/12900k with a 3090, and the fps on 12400 is a lower when you get to some games at 1440p, and a lot lower at 4k...so if you get cpu bottlenecking on a 3090, image with a 4090
I don't completely disagree, but I don't think having a better CPU is going to help when most people will be bottlenecked by the refresh rate of their monitors. Half the time. I think bottlenecking is just something people say to justify spending more money on something that deep down they really know they don't need to.
If you are being held back by your CPU but your refresh rate is still above and beyond what you need, then it's completely superfluous to get a better one.
This is with a 5800x https://www.techpowerup.com/review/gigabyte-geforce-rtx-4090-gaming-oc/31.html
Then I look at something like this and see OP's CPU up there with the 12 600 at 1440p
So it is not unreasonable to extrapolate from that they will be very close at 4K also and judging by the first benchmark people are not going to be held back unless they are running over a 144Hz monitor at 4K which of course is really common...
Hopefully someone will do a benchmark with both those exact bits. I would never tell somebody to buy a better CPU though because they might be limited to 120 FPS at 4K Max settings
Honestly, I'm with the above saying it's a rather strange and imo unbalanced choice of cpu to go with the gpu....
hence my 1st question was, what resolution are you playing at..so yes, really I should have asked what monitor he's using to get a bit of an understanding. I never told them to buy a better cpu. The idea of a forum is to get advice and learn(or that's what i use it for), def not to be insulting etc
However, your extrapolation about being held back unless 4k gaming at high refresh rate I think is pertinent as goes towards the whole point of this card. If you're going to be gaming at 1080p or 1440p again, not unreasonable to say, you shouldn't be using this card really. It's the most powerful non professional card every released(so far), very expensive(3090ti excluded as launched in mining shortage, prob at that insane price to make the 4090 seem reasonable), designed to push 4k gaming as much as possible..if you're going to be gaming on a 1080p screen at 120hz, you'll get exactly the same fps with a 3060ti, and you can save yourself £1500 at the same time, in which case the argument is not the use of a 12400(arguably the best bang for buck intel cpu atm), but whether you then have the right gpu, or whether you should return and get one more suited for the intended use
If you're spending £2k on a gpu, in order to maximize it's potential, it's only the beginning of your investment..as you say, to maximise it's potential, you'll need a fast refresh rate 4k screen and a powerful cpu to really bring out all it's potential, so £2k is just the start, otherwise you might as well get a cheaper gpu and save some cash.
The op asked what mobo he needed, so my assumption is he's building a new rig for a 4090 and just got a 12400. Yes, as above, the 12400 is a very good cpu for the price, but I just watched a yt of the 7600x cpu v the 12400 cpu with a 3090. over 6 games the 7600x returned av of 125fps..the 12400 returned 107 fps..so using the 7600x returned a 16.8% better framerate than the 12400...with a 3090..this difference will only increase with a 4090...so lets say 4090 diff becomes 30%(arbitrary for example sake), then 30% lost frame rates on a £2k card is £600 wasted money, when you can change the 12400 for a 12700K, spend £200 more on cpu and gain £600 worth of fps back as unleash the potential of gpu...sorry, bad example really, should really look at 12400 v 12600k/12700k, but only ones ai could see were with a 3080..and in this example using 12700k as similar performance to the 7600x(which is a cheaper cpu)
So, bad example aside, as said, it's an odd pairing...if OP can afford a 4090, then possibly he can afford a better cpu to maximise it's potential, and maybe point out the benefit in doing so. I mean, I certainly can't afford a 4090, so not going to belittle him for getting one, just if I did get one, would then be looking to change the screen I play on etc.
side note, hadn't seen the techpowerup review..having a 5800x myself, I like the results..
@Craig_d1 Yes I think we've both made some assumptions because OP didn't really give much detail. We don't know if they already have the CPU nor what res.
I think I agree with what you were saying but is dependant on if OP already owns the CPU, or perhaps that is the best they feel they can afford because most of their budget went on the GPU.
I suppose until we actually know any of that is pointless trying to guess
I'm on Ultrawide / 120hz
that would be a 1440p ultrawide agreed? and are you building from scratch around a 12400 with a 4090? if you haven't bought it yet, the 12600k oem that OCuk sell isn't hugely more than a 12400..if going a 'k' cpu build, I'd pair it with a z690 board . Ram, intel not so essential with higher speed so 3200C16/3600c18 more than good enough (3600C16 if similar price)
MSI make a good set of boards for Z690, and here's a spread. The Z690-a up there with best budget z690 board with, mid range is the tomahawk, and edge adds slightly more powerful vrm's(75A as opposed to 70A) and think all 4 nvme slots gen 4(1 is gen 3 on tomahawk), and slightly more rgb with the dragon on the vrm heatsink
My basket at OcUK:
Total: £809.98 (includes delivery: £0.00)​
[/INDENT​
if you don't plan on getting a 'k' skew cpu, and don't plan any overclocking, a B660 board will save some cash. Best budget b660 is the msi pro b660m, and then the mortar wifi decent premium board which will run cooler.. both a micro boards. If you want full size ATX then the best b660 is the tomahawk for about £200. The Strix B660 gaming a also very good, and seen that below £200 now also..​
My basket at OcUK:
Total: £339.94 (includes delivery: £0.00)​
All these boards will allow you to drop a 12900k in(have to see about a 13900k for the budget boards), but b boards don't allow cpu overclocking...except the B660 Mortar, but you need the 'Mortar MAX'​
I would def look at some yt of gaming using a 12400 v a 12700k paired with a 3090 at 1440p..you'll see you loose some fps as the cpu pushed to max by gpu(so 4090 be similar with ultrawide)..if you're happy with that, go for it​
For Ram, i'd get 32gb (2*16)..seen 32 gb rgb veangence rt gunmetal 3600C16 for £134..vengeance rgb pro 3600c18 for £117 or vengeance lpx non rgb 3600c18 for £109​
lastly, shop around..shops have offers at diff times, so prices can vary from place to place​
Also seen NZXT N7's on offer reduced to £229, N5's reduced to £159..N7 seems to have fairly good reviews and looks good too..worth a look(but need to check some more reviews)​
