Spec me a motherboard...
2 Nov 2004
I would like...
Core2Duo
LAN
Firewire ports
Lots of USB
Dual graphics isnt a priority
7.1 onboard isn't a priority
minimum 4 SATA ports, preferably 3gb
Overclocking not a priorty, price not neccessarily a concern, stability and quality is...
It's been a while since I purchased a mobo so assume ignorance
Don't laugh, but but something based on the Intel 945 chipset would be ideal. ASRock ConroeXFire-eSATA II is completely stable, has all the features you require, admitedly it doesn't overclock, but it's had good stable drivers for over 7 months now and it's even quick for a 'legacy' board. Cheap too.
Don't be puit off by ASRock - it is ASUS, built in an ASUS factory with the same QA staff looking after both sets of production.
