- 2 Aug 2005
- Cleveland, Ohio, USA
I'm mulling over the idea of building a MythTV system. MythTV is a system of PVR software for Linux. It uses a client-server model so I am going to have the DVB and analog cards in a powerful computer stashed away. It'll feed recorded TV shows over the network to a frontend client. The idea behind this is to minimize the size and power necessary for the machine. I'd like to get away with one 60 mm fan for it all but I'm flexible.
I wanted to use an old laptop I have, Pentium M 1.5 GHz with 855GM graphics/chipset, for the frontend but I'm having all sorts of issues, mainly that the thing is horribly broken with no working HDD or ODD. Wait a minute, that's probably why I stopped using it in the first place! Since it won't boot from USB or firewire I'm looking at alternatives.
I'd like to see what a cheapish SFF PC might be able to do. All it needs to have is VGA and S-Video out and a 100 Mbit Ethernet port, and a 2.5" IDE port or Compact Flash slot. I'll be running the whole thing from a 1 GiB Compact Flash card.
I'd very much like to avoid any VIA bits, either CPU or chipset. It would be an extra bonus if I could reuse the skt479 Pentium M or the SODIMM DDR memory. What can you show me? I'm quite the n00b when it comes to small lower-powered devices.
EDIT: I'll be custom making a case for it so form factor doesn't matter. I'd like to keep the overall height under 100 mm if possible so I won't be using any expansion cards. Do SFF boards ever come with discrete graphics like some laptops do? nVidia graphics onboard would rock my socks.
