spec me a netbook
1 Jul 2009
I've seen the Acer Aspire One 722 11.6 inch Netbook which looks good for around £300. I want a netbook with at least 7 hours battery, a decent screen resolution, dual core but I'm not bothered about the graphics card as it wont be for games. Anything under £300 would be good.:cool:
Make sure you can easily upgrade the ram and it's a dual core one....
If its DDR 3 some netbooks if not most use low power memory modules so check before ordering
