Hi all,
At work we have a system that monitors clients servers and shows details about them on a screen, this is a web based thing that we currently use a laptop to connect to and then the laptop plugs into the screen and outputs what we need to see.
We want to tidy this up and use something that will hide behind the screen and do the same job.
I'm after a very small net top that can perch on top of the mounting bracket that the screens are mounted to. We need 3 of these and they all need to be able to out put full HD resolution.
I think the height of these needs to be slightly less that 20cm if possible, the cheaper the better.
I am debating if we should use netbooks so that we can use the keyboard for occasional re-configuration, but this is not essential. What is essential is they must output full HD over VGA or HDMI.
Any suggestions would be really appreciated as they are looking to order today if possible.
Thanks,
G
Thanks,
G
