Spec me a network card xD
19 Jul 2010
Belfast, Northern Ireland
I need a fast affordable wireless network card for gaming. Low ping high performance :p cheers
Yes a desktop but those powerline kits are a bit pricey. I'm not sure if I will be able to use one, with my setup.
I use Edimax EW-7728In.
Constant 4/5 signal for me and worked out of the box. Didn't need to use supplied CD or anything.
I suppose they do tend to cost a bit more than a wireless adapter, but not loads more - this kit costs £34.46 and if you want even more speed this kit is £10 more.
In terms of actual speed, powerline will tend to give you faster transfer speeds and definitely less latency, so the extra price can be justified.
I use a powerline kit (solwise) and its fantastic. The xbox doesn't slow down online like it did with wireless and for hd media streaming they are well worth it.
