Spec me a network
23 May 2006
Blythe
hi can you spec me a good fast and stable network,
a wireless router & pci card,
I do a lot of gaming so I might invest in powerline but I want to see what wireless it like first,
the last router i had was rubbish and needed reseting every 30 mins both wired and wireless, it was a linksys wag54g have they got better since then? I'm on adsl btw
collisster
I have a WRT54G never had it ever go offline, or DC in 3 yrs of owning it, and I run my main rig gaming, my downloading rig via cable into it,
And my lappy via wireless no problems
thanks furton, is that using good wireless technology? should I get homeplug for my gaming?
Wireless should be fine depending how strong the signal is from the router to your PC. As for the other two, no idea I'm afraid as I've never used them. Google is your friend.
thanks, I'm in an 200 year old 4 bed house with good old brick walls, I plan to put the router downstairs next to the phone socket, have wireless for the laptops and maybe homeplug for gaming but I'll see how I get on with wireless first.
