Spec me a new CPU block and water cooling system...
3 Nov 2013
Surrey
Hi Guys,
At the minute I'm running a slightly off-branded closed-loop CPU cooler which is performing ok, but I'm looking for an upgrade that can properly do the job for me.
I have an AMD FX 4300 CPU @ 3.8GHz (AM3+ socket)
I already have a Corsair SP120 on my 120mm rad and it looks, sounds and performs great.
So any suggestions on CPU blocks, rads, tubing etc would be much appreciated.
Also I was planning on using Mayhems Pastel Blue (blueberry or whatever it's called...) coolant when I build it, has anyone got any experience with this, or can recommend anything better?
Thanks in advance :)
What the hell cooler are you running currently? I think somthings wrong with the reporting software or the temp probes on the cpu.
Haha thanks Mynight, i suspected there was something amiss with the temperature reporting... I'm taking CoreTemps word for it at the minute!
Thanks for the recommendations, I'll have a look at those :)
Haha I may have accidentally found the best CPU cooler on the planet :D
I'm looking to spend a couple of hundred... For the block, rad and tubing
