If you want to stay on the TV side of things, then I'd recommend the Sony KDL42W705B or KDL42W653A. They're pretty much the same, the first one is from 2014, the second is from 2013. Whichever you can find, it's all good. Those two models are currently the input lag champions in HDTV side, and they should be good for computer usage, too. Even for gaming. Though they require a 1m viewing distance, at minimum.
